markbng's avatar
markbng
Follower
Aug 30, 2013
subversion newbie questions
Hi,
At the moment I am trying to set up a subversion server on my ReadyNAS312. I have in installed "subversion" 1.6.12 from Steve-O from the "Available Apps" tab on my Readynas. I have a "Projects" directory on my hard disk that I want to store on my SVN server. This directory has multiple projects (let's call them "Project1", "Project2", etc). The first step is to make an exact copy of my project map on the SVN server so I can submit my updates on my NAS. Where can I read detailed information about a step by step guide to get this working? I also want 1 of the project directories to become available to someone that works with me on this project. So he will get access to "Projects\Project3". He should not be able to get access to the other projects. I will only sync my Projects map (with this Project3 map). How can I easily set this up? Sorry for the newbie questions, but I would be very grateful to you if I would get this working. I don't mind reading the how-to guides, but I can't find the how-to guide for the subversion plug-in.
Kind regards,
Mark
Ps. I am using TortoiseSVN on my x64 Win7 computer and I was able to log in with putty into my readynas and I have used "svnadmin" and "chown". Didn't do the apache commands (enabled http on the SVN dir).
ProSupport for Business
