Etz
Feb 24, 2011Aspirant
[super-poussin] NasMonitor update for Sparc?
Maybe super-poussin could update sparc version also.
It`s very outdated now... :oops:
Also Version 2.9 contains Loadavg 1.1 which is ancient and has broken graphs in FF 3.6 due to CSS issue.
Trying to figure out how to do it myself, but it would be much easier if the author would update whole package.
Bascy wrote: if you disabled the auto update feature, this error won't appear (just a workaround)
Auto update is disabled here. (Unticked)
Thanks though.- TechZ1Aspirant
super-poussin wrote: can you try : http://www.readynas.com/contributed/sup ... or_3.2.bin
Just tried v3.2 for SPARC. Even installed PHP v1.1 (since this is a new NAS). Each time I click "Load ....", I get the same issue. Across multiple browsers.
- Have you tried with the newer PHP v1.3 from Super Poussin?
viewtopic.php?f=47&t=21458&p=117125&hilit=PHP#p117125 - TechZ1Aspirant
InTheShires wrote: Have you tried with the newer PHP v1.3 from Super Poussin?
Just installed that, same issue. - I'm using NAS MONITOR 3.6.15 on my Ultra x86.
In Opera, new and old releases, all work fine, and in NASMon, I can access, server, charts, settings and Logout. (Once properly configured as per info posted here)
However, in Firefox, latest version. in NASMon, I can only view charts and login, The other pages give just a message saying the redirect is never going to work, so stops.
Anuybody else get anything like this, with different browsers?
Thanks.
4.2.21. x86 - EtzAspirantEnable HTTP from frontview and configure LoadAVG via web browser (Redirect error will go away) to use HTTPS only and then disable HTTP in frontview.
or another solution is edit LoadaAVG files directly and comment out http part or replace it also with https in security.php
If I remember correctly...unfortunately I switched to MRTG, so i cannot look from my config anymore... :|
Problem is that by default HTTP is disabled on ReadyNAS, only HTTPS is available (hence its a security reason), but LoadAVG needs HTTP by default.
There is HTTPS->HTTP redirect but unfortunately it goes into loop and never completes, and so the error is displayed, which you just posted...
It will happen on all browsers, only error message itself would be different... ;) Etz wrote: Enable HTTP from frontview and configure LoadAVG via web browser (Redirect error will go away) to use HTTPS only and then disable HTTP in frontview.
I might be mistaken, but this seems like a Firefox issue to me. Opera gives me no error messages at all and correctly displays the pages.
HTTPS can be set to either option in Loadavg, and it still works in Opera.
HTTP only in Firefox causes the loop you mention. HTTPS in 'fox gives the outcome described in my OP.
HTTP is not enabled in Frontview.
I'll have a look at MRTG. Thanks. Was MRTG a simple proceedure, or am I likely to run into the unexpected hassle I encountered with Munin?
EDIT - Just so it's clear, as I see the thread title mentions Sparc. The issues I'm explaining, are relating wholly to an x86 U2+. (My Sparc NAS runs in a vanilla state, for primary backup purpose only, no addons, and a very minimum configuration.)
TIA.- EtzAspirant
InTheShires wrote: Etz wrote: Enable HTTP from frontview and configure LoadAVG via web browser (Redirect error will go away) to use HTTPS only and then disable HTTP in frontview.
Its not an Firefox Issue only, if you open that file on editor, and look at the code, you will get the clear picture, why it works that way, and gets into a loop.InTheShires wrote: I'll have a look at MRTG. Thanks. Was MRTG a simple proceedure, or am I likely to run into the unexpected hassle I encountered with Munin?
TIA.
MRTG is pretty straightforward.
From SSH, apt-get install mrtg...and so on...Only hassle is that you need to create your config files manually.
Also SPARC perl is "incomplete" modified version , so you have to tickle littlebit with it. On x86 it runs without any modifications.
If you want it to run on SPARC, I can upload those missing modules somwhere, when I get home...
https://www.evernote.com/shard/s36/sh/2 ... 631e03887e
Unfortunately theres no add-on package, so you have to do it all manually.
If you have 2 ReadyNAS`es you could always install MRTG on x86 one, and pull other NAS data via SNMP (yeah I know, business feature and doesnt exist/work/etc..., but in fact it still exists on NAS and can be enabled).
