guysmithuk
Apr 20, 2026Aspirant
Swapping disks from failed unit
hi i i have a readynas duo v2 with 2 raid drives the unit has failed suddenly- the light flashes regardless of one or two or no drives so i think its a dead unit. i have brought a new unit of the ...
- May 10, 2026
All sorted now thanks.
new ( old) unit works well.
thank you
Apr 20, 2026Guru - Experienced User
guysmithuk wrote:i have brought a new unit of the same type
Can't be really new, since the Duo v2 was replaced in 2013.
There are a lot of folks who mistakenly think they have a Duo v2, when they actually have something else. That's on Netgear, their branding wasn't well considered.
The Duo v2 says ReadyNAS Duo v2 on the front panel. The original Duo says ReadyNAS Duo on the front panel. Ignore any other labels you see. Note if you don't see "Duo" on the front panel, then you have something else (perhaps an Ultra 2 or a Pro 2).
Anyway, first put in a scratch disk, and do a basic install. Check that the firmware is current (5.3.13 for the Duo v2, 4.1.16 for the older Duo v1). Once checked, I suggest powering down and migrating the disk to the second bay. Then make sure it boots. If you fail to do this, then the replacement could install old firmware on the disks.
After that, you can just migrate the disks with the NAS powered down.
- guysmithukApr 20, 2026Aspirant
thanks for the reply.
definitely v2!as it’s on the front panel
and yes - the unit i’m getting is second hand.
by scratch disk do you mean a new hard drive?
once i have done this and it boots with a new disk- do i try disk 1 or 2 from the old machine first?
guy
or did you mean move the scratch disk from bay 1 to 2 just to check it boots?
guu
- StephenBApr 21, 2026Guru - Experienced User
It can be any working hard drive you have - keep in mind that it will be reformatted.
Yes. Just to make sure the new unit is working.
Note this maybe could have been a failing power brick. So before trying any of that you could try using the replacement's power brick with the failing Duo.
- guysmithukApr 27, 2026Aspirant
Thank ls for all your advice. I’m just waiting to receive the replacement unit and I’ll try the things you suggest
- SandsharkApr 28, 2026Sensei
I hope you verified the replacement unit is also REALLY a V2. There are a LOT of "V2" units for sale that are not, for the reason StephenB explained. If the replacement is not a real V2, DO NOT put your drives in it, they will be re-formatted. But the V1 and V2 power supplies are compatible with each other, so you can still try that.
