RobW1
Apr 16, 2009Aspirant
Torrent downloads crash device
Hello, I have a Readynas Duo with a 1TB samsung spinpoint drive. Modem/Router is Netgear DG834GT with DGTeam firmware version 848 When downloading a torrent my nas regularly hangs. This can hap...
RobW1
Apr 27, 2009Aspirant
chirpa wrote: If you disconnect/reconnect the network cable, can you reach it? It is possible the high number of connections is overwhelming your router, causing the connection problems.
No that doesn't work. The nas doesn't show up in raidar, and I can't ping it either (nas has a static ip address). To be honest I'd given up using it for downloading torrents which is pretty frustrating as thats one of the reasons I bought it.
i did think that the number of connections could be an issue. Thats why I installed Transmission as it has the ability to modify the number of connections, but these are set to a pretty small number by default.
I'll set something downloading tonight and see if anything shows up in the logs..
Incidentally, this happens on firmware 4.1.4 T70 and 4.1.5
