MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
MrAsker
Jan 23, 2012Tutor
Thanks for your reply
That does seem like the problem but ..
- I've got uPNP enabled in the WNDR3800
- I have the setting "use port forwarding ..." set for Transmission
- I'm randomizing the port but I've also tried with different fixed ports
- I've got the same ports specified in settings.json (60000-60999) and opened in the router
- Fixed or Random, all these ports are all sent to the NAS and both for UTP and TCP
- In the Router logs I can see that that the Portforwarding is done so I'm pretty sure this works
- On the NAS with Netstat -an | grep -i [portnumber] I can see that there are a lot of connections on the current portnumber
Regardless of this the WebGUI says "Status: Unknown" for the portforwarding and the speeds are as previously described.
Feels like I'm either missing something very simple but I can't see it or this is a very odd and very specific problem that "only" I have.
So, any other ideas? I'm open to any help and any suggestions.
