MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
JarnoG
Jan 24, 2012Guide
if the menu of the WNDR3800 is something like the one on my WNR2200, then there is a page with the current upnp ports. Can you check if the port assigned by Transmission is set to the right IP-address. It might happen that it registers the port-forwarding to the wrong IP, for instance that of the ReadyNAS Remote-IP (if you have that running).
This should not be a problem if you turn upnp off in Transmission and manually set the port in Transmission to a fixed one and forward that port to your NAS's IP.
