MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
JarnoG
Jan 24, 2012Guide
I think the connections to port 60221 (2nd code block) are the peers connected to you and the other ones (3rd code block) are either to other services (CIFS,HTTP,etc) or are the connections you made to other people to download from.
Your router log shows that it is forwarding the right port to the right IP, so that shouldn't be a problem. I've got no idea why it doesn't delete the unused upnp ports.
It also shows that you're connected to plenty peers, so that shouldn't be a problem either, which means I'm kinda out of options...
