MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
MrAsker
Jan 25, 2012Tutor
I think you were onto something when you wrote:
The more I think about the more I think this is the problem.
I wish I could get a better logging from Transmission so that I can understand what it is doing and more importantly, what it is not doing. I've search but I can't seem to find a way to turn on better logging. Do you know of any way to do it?
So, for as long as you are asking the tracker for new peers, you can download fast and you will upload to the peers that you are downloading from. However, incoming connections get blocked, so others will not connect to you. Eventually, this reduces the amount of peers you are connected to and with that, your download and upload speed.
