MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
JarnoG
Jan 25, 2012Guide
I'm assuming Transmission is keeping some kind of log somewhere, but my knowledge (or lack thereof) of Linux tells me not to enable SSH so I can't go look for it.
What you can try is disabling upnp on your router and enabling a DMZ for your NAS. That way all ports are forwarded to your NAS. If that would give you better downloading, then there is most likely some port-forwarding problem (or another problem in your router).
