MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
MrAsker
Feb 04, 2012Tutor
I 've started to get better speed, 200kb/s plus which is better not close to my max of 1-1.5Mbyte/s which I should be able to get.
So, I checked the daemon.log for more info and since last time I see a lot of "Could not connect to tracker (announcer.c:990)". Afaik this is a problem if the port(s) used are not forwarded in the FW to the NAS (where I run transmission) but I've double checked and "random ports" I've designated in the settings.json file 60000-60999 and the default ports 6880-6999+51413 are forwarded to the NAS so I'm pretty sure this is not the problem. This is with uPnP disabled so I will try again with it enabled.
I find it strange that I do get better DL but still a lot of errors in the logs.
tbc
tbc
