MrAsker
Jan 23, 2012Tutor
Transmission 2.42 Performance Problem
I have a strange performance problem that I can't make heads and tails of. Maybe anybody have any ideas,? What I see is that shortly after I start Transmission I get decent DL speed and UL speeds, ...
MrAsker
Mar 12, 2012Tutor
OK, now I'm back at the terrible speeds that I had before and I have no idea why.
I've tried with uPNP enables and disables in Transmission and it does not make any difference.
I've tried limiting the Active DL:s to <5, <10, <20, <30, etc, and it doesn't seem to make any difference.
I've tried only having the torrents with 1000+ seeds Active, and it doesn't seem to make any difference.
I've tried having only smaller (<200Mb) and only larger (4Gb<) torrents Active, but it does not make any difference.
I've naturally stop:ed and started Transmission a number of times to see if it's a port issue, but it does not seem to be so.
In the daemon.log I can still see a lot of the errors above but I can not make heads or tails of if it's worse or less then before. It's simply to many of them.
Anybody have any help?
