devilsrear
May 24, 2012Aspirant
Transmission 2.52 - ReadynasDuo
Hi Any sign of this coming along? Now that the Duo2 is out - is the Duo eventually going to be phased out? Do I need to buy another NAS? Cheers
May 25, 2012Guru - Experienced User
The v2 has a different architecture, so if you move your v1 disks over it will reformat them.
devilsrear wrote: lol really stupid question (and off topic) if i switch to another nas - duo v2 or nv? can i swap the drives out of my existing duo? or would it be simpler just to buy a new nas and get new drives?
If your v1 meets your needs overall, there is no reason to rush to replace it. If you do upgrade, consider both the ultra/pro lines and the v2.
