HERBIEO
Jun 18, 2012Aspirant
Transmission 2.52 Incoming connections
Does anyone know what transmission is doing when no torrents are running, because i noticed in my router logs a lot of incoming connections to Transmission seems a bit strange when no torrents are active.
NAS ip 192.168.0.100 Transmission port 51413
[LAN access from remote] from 85.75.255.217:56021 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:14
[LAN access from remote] from 86.10.201.228:48687 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:14
[LAN access from remote] from 109.60.121.107:57098 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:13
[LAN access from remote] from 178.223.11.238:39516 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:13
[LAN access from remote] from 95.85.155.59:61297 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:13
[LAN access from remote] from 93.182.44.235:35691 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:13
[LAN access from remote] from 184.88.215.214:38658 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:12
[LAN access from remote] from 85.241.182.240:16317 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:12
[LAN access from remote] from 75.74.13.229:30540 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:11
[LAN access from remote] from 81.210.11.116:10359 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:10
[LAN access from remote] from 89.73.219.34:1128 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:09
[LAN access from remote] from 37.6.156.71:17941 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:09
[LAN access from remote] from 90.211.80.253:57648 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:09
[LAN access from remote] from 188.129.121.73:15078 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:08
[LAN access from remote] from 189.173.123.16:20411 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:08
[LAN access from remote] from 85.74.156.28:15760 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:08
[LAN access from remote] from 217.216.220.183:22854 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:07
[LAN access from remote] from 195.56.102.212:15964 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:07
[LAN access from remote] from 41.218.206.55:10051 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:07
[LAN access from remote] from 187.10.19.59:37868 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:07
[LAN access from remote] from 173.84.185.42:40485 to 192.168.0.100:51413, Monday, Jun 18,2012 19:15:06
The log goes on and on.
- StephenBGuru - Experienced UserAre you forwarding 51413? or is uPNP managing it for you?
- HERBIEOAspirantuPNP is managing it, maybe i should turn off uPNP and forward it myself see if there is any change.
- StephenBGuru - Experienced UserIt is better if uPNP manages it, as then the port should close when transmission is done with it.
I am thinking two things -
(a) maybe torrent clients are still attempting to connect to you, even though there is nothing active. Perhaps a tracker has not yet updated for instance.
(b) maybe you actually still are seeding something? - HERBIEOAspirantits strange i have not even got any torrents in the list, and no incomplete or complete torrents in the downloads folder,
just checked router logs and its still going on it is as like i do have something going really strange.
[LAN access from remote] from 190.254.53.18:18574 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:11
[LAN access from remote] from 196.202.208.56:24386 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:11
[LAN access from remote] from 2.49.247.156:60509 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:11
[LAN access from remote] from 77.122.207.45:33358 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:10
[LAN access from remote] from 89.122.142.206:27973 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:10
[LAN access from remote] from 89.178.145.180:21076 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:09
[LAN access from remote] from 200.117.41.156:46182 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:09
[LAN access from remote] from 189.152.233.127:21482 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:07
[LAN access from remote] from 79.33.65.89:50630 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:07
[LAN access from remote] from 166.250.69.211:6899 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:06
[LAN access from remote] from 2.107.239.98:63721 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:06
[LAN access from remote] from 178.128.165.121:59441 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:05
[LAN access from remote] from 79.167.3.64:10020 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:04
[LAN access from remote] from 81.182.45.65:33123 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:04
[LAN access from remote] from 188.24.105.89:64390 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:02
[LAN access from remote] from 79.139.141.145:61529 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:01
[LAN access from remote] from 110.174.173.37:45590 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:01
[LAN access from remote] from 94.70.79.177:41685 to 192.168.0.100:51413, Monday, Jun 18,2012 22:18:01
[LAN access from remote] from 186.148.151.3:48416 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:59
[LAN access from remote] from 79.101.212.95:16074 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:59
[LAN access from remote] from 83.86.57.208:14028 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:59
[LAN access from remote] from 188.126.26.161:58523 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:57
[LAN access from remote] from 91.229.7.10:1048 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:56
[LAN access from remote] from 125.44.101.66:22844 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:55
[LAN access from remote] from 174.97.217.110:21966 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:55
[LAN access from remote] from 201.240.218.44:1669 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:54
[LAN access from remote] from 151.77.87.3:10003 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:54
[LAN access from remote] from 78.233.25.219:51413 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:53
[LAN access from remote] from 86.174.80.128:58832 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:53
[LAN access from remote] from 92.29.118.191:55325 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:53
[LAN access from remote] from 24.166.40.35:35430 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:52
[LAN access from remote] from 67.212.108.88:17517 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:52
[LAN access from remote] from 91.184.217.230:15478 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:51
[LAN access from remote] from 69.124.201.78:10007 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:51
[LAN access from remote] from 88.177.31.220:20109 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:51
[LAN access from remote] from 84.55.60.252:27190 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:50
[LAN access from remote] from 67.222.205.138:51694 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:50
[LAN access from remote] from 60.237.25.36:10474 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:50
[LAN access from remote] from 114.40.83.181:7514 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:50
[LAN access from remote] from 203.217.145.150:12325 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:48
[LAN access from remote] from 188.24.205.187:42174 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:48
[LAN access from remote] from 95.63.16.11:1839 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:48
[LAN access from remote] from 99.73.222.151:18810 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:47
[LAN access from remote] from 93.73.217.101:26262 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:46
[LAN access from remote] from 92.84.226.147:20563 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:45
[LAN access from remote] from 46.177.65.108:28661 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:45
[LAN access from remote] from 117.223.32.64:24675 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:44
[LAN access from remote] from 69.132.47.171:31195 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:39
[LAN access from remote] from 94.15.112.73:53186 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:39
[LAN access from remote] from 41.100.206.85:26542 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:39
[LAN access from remote] from 65.35.78.30:44376 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:39
[LAN access from remote] from 76.178.80.190:12336 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:39
[LAN access from remote] from 94.79.45.250:39281 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:38
[LAN access from remote] from 41.34.219.190:15779 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:37
[LAN access from remote] from 98.208.32.254:41627 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:37
[LAN access from remote] from 151.49.58.35:12401 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:37
[LAN access from remote] from 98.176.32.197:55110 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:35
[LAN access from remote] from 195.13.38.136:12739 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:35
[LAN access from remote] from 86.198.181.145:18090 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:34
[LAN access from remote] from 118.169.131.16:16001 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:34
[LAN access from remote] from 85.201.137.211:10622 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:34
[LAN access from remote] from 95.134.49.100:42078 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:34
[LAN access from remote] from 82.212.171.29:62973 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:34
[LAN access from remote] from 50.97.88.76:15031 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:34
[LAN access from remote] from 221.118.242.18:26900 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:33
[LAN access from remote] from 212.118.28.88:21655 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:33
[LAN access from remote] from 190.118.186.228:32453 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:32
[LAN access from remote] from 99.234.193.43:23804 to 192.168.0.100:51413, Monday, Jun 18,2012 22:17:32 - HERBIEOAspirantWell just disabled Transmission and its stopped, so now i will restart Transmission and see what goes.
- HERBIEOAspirantEnabled Transmission and lots of incoming connection again, do you think this could be a bug with transmission ?
maybe you remove a torrent and Transmission is still acting like its there. - StephenBGuru - Experienced UserDo you have DHT enabled in Transmission? That is quite possibly the cause.
- HERBIEOAspirant:lol: Disabled everything DHT PEX and still incoming connections they only stop when i actually disable transmission, just seems while its running it keeps excepting incoming connections.
Edit: Maybe its just borked because when i choose the ketu interface it does not change, it confirms its changed but when i go into it its still the standard interface. - BikeHelmetAspirantI'm guessing that's a plausible deniability feature. Everyone with it installed has the same odd sorts of traffic, therefore ISPs can't single you out for being bad. :P
I have noticed the same thing about all torrent clients that I tried - even with DHT/PEX/etc. disabled. If I start up uTorrent, my router connections start climbing into the thousands, even though it's totally empty. - HERBIEOAspirantIf i start up uTorrent with no torrents running i get incoming connection about 1 every minute, but Transmission its about 1 a second seems a bit extreme, well sometimes its multiple connections at the same time like below, and thats no torrents active.
