HERBIEO
Jun 18, 2012Aspirant
Transmission 2.52 Incoming connections
Does anyone know what transmission is doing when no torrents are running, because i noticed in my router logs a lot of incoming connections to Transmission seems a bit strange when no torrents are act...
Jun 18, 2012Guru - Experienced User
It is better if uPNP manages it, as then the port should close when transmission is done with it.
I am thinking two things -
(a) maybe torrent clients are still attempting to connect to you, even though there is nothing active. Perhaps a tracker has not yet updated for instance.
(b) maybe you actually still are seeding something?
