  • devilsrear wrote:
    dennild wrote:
    hey i would allso really like and update for my duov1 since the raidator update i cant get any of it working!
    Hi my big concern now for us duo v1 users using transmission is that they have now released RAIDiator 4.1.9 - the latest version 2.42 is NOT compatible with this version of RAIDiator.
    Hi,
    I have to disagree. I've a ReadyNas Duo and upgraded to RAIDiator 4.1.9 yesterday.
    After reboot, TransMission wasn't accessible.
    After performing a local update with the TransMission 2.42 binary,TransMission works perfectly again.
  • Thanks - will give that a go. Saying that I've just splurged out on a duo v2 - as they are currently on offer @ £99 for a diskless unit
  • TKCable wrote:
    Hi,
    Good News! I stand correct, upgrade to 4.1.9 then a update to transmission 2.42 does work :) - definately tried that before, maybe it was specific to the 4.1.9 being a beta
  • Yeah, update to 4.1.9... you can then re-install Transmission. You'll probably lose access to shares but Netgear don't seem at all concerned and treat their customers as 'nobodies' (the user that shares are changed to after updating..)
  • Worked for me aswel. Reinstalled Transmission 2.42 and it (seems to) works like before.
  • I confirm that since the 419 uppgrade transmission 242 is very unstable. Re-installing, re-booting or whatever does not help.
    I have given up now and will order a synology 212 this week as a replacement.
  • Tranmission 2.42 won't install on the latest RAIDiator 4.1.9. Even tried a different browser.
  • I got a readynas duo, radiator 4.1.9 and tried to install Transmission add on. But don't works.
    I uninstall this add on but two directories still in my readynas. And I can't delete it... I tried to delete in shares setup, and fine. But when I accessby network they still there... I need some help to delete them!!
    Thanks for some help...
ProSupport for Business
