ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
Forage
Jul 20, 2013Apprentice
canprof wrote: I think I spoke too soon on my previous post. I have found the settings button (blame my failing eyes for the initial failure). But I can't figure out how to start a torrent. I have a torrent file in my download folder. How do I get Transmission to recognize it and start a download process?
You have two options to start downloading torrents:
- Go to the web interface and click on the top-left button (Open Torrent) and either point to the torrent file or torrent url
- Place the downloaded torrent files in the watch folder to start download automatically. The watch folder is located within the Transmission network share folder: browse your network, go to your NAS share, here you have the folder transmission/watch-dir
You can edit the settings.json file located in the same transmission folder on your network to change the default watch folder location or more advanced settings. Make sure you disable the transmission add-on first before you start editing this file. Enable the add-on again when you're finished.
