ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
Forage
Jul 21, 2013Apprentice
canprof wrote: Thanks for this. I'm confused about the "Open Torrent" button. When I click it, it opens a box allowing me to "Upload Files" from file or url. neither one seems to do anything, and I want to download anyway.
You have to point to a torrent file with either of the two. Try the file upload function with a torrent file just as the one you would be adding to the watch folder (one that isn't downloading already). That should present you with a dialog, allowing you to start the download and optionally select the files you want to download. You've found a bug if that does not work.
