ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone,
this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on.
Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=390784
The latest version is 2.82-0.06.
Happy ReadyNASing! :D
Sergey.
Sergey.
- ashaniAspiranthello,
any news on latest update of Transmission 2.80, when can we expect the update for readynas v2
Thanks for the good work. - ssurbaGuideHi Duov2,
you can edit settings.json by using your favourite text editor, the file is in network share of your ReadyNAS:
\\<name_of_your_readynas>\transmission\settings.json
Cheers,
Sergey. - Duov2AspirantHi,
I am not sure is it just me or is there no options to edit the settings.json from the web interface? The interface made by Whocares? had an easy access settings.json button to edit the settings...
I used to be able to set a remote login username and password from settings.json but i dont see an option right now.
Please assist
Thanks - ssurbaGuideHi Newklear,
it is safe to visit my site, I've just checked it - no viruses.
As this add-on is not officially supported by NTGR I cannot get it posted on the corporate website. But again, there should be no problem to download it from my website.
Cheers, Sergey. - NewklearAspirantHello,
This might just be the overly paranoid me talking, but is it safe to visit "http://www.sergeysurba.com/projects/transmission"..?
My anti-virus software (avast) blocks the website and tells me it contains some dangerous javascript code and/or a trojan horse or something.
Can it be downloaded as an add-on from an "official" netgear site somewhere?
I have been using Transmission for over a year but since the random crashes of my NAS started happening i thought i'd give this one a try, especially after the comment from "whocares?" that the transmission add-on had been discontinued. - devilsrearAspirantgreat update and free - working like a dream :)
- DcoreAspirantnever mind. it displayet in Shares after 2 full restart :-)
- DcoreAspiranthi
and thanks for a grate addon, is there any whay to hide the transmission folder/share from som users or will it be included in a later release?
kind regards - ssurbaGuide
super-poussin wrote: did you compile with --disable-nls --enable-lightweight --enable-largefile ?
Hi super-poussin,
I've compiled with --enable-lightweight only.
I did not want to disable NLS, because there could be files with national characters in names.
It seems that support for large files is enabled by default and as far as I know there is no option --enable-largefile in ./configure (as of v.2.77).
Regards, Sergey! - super_poussinVirtuosodid you compile with --disable-nls --enable-lightweight --enable-largefile ?
