ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone,
this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on.
Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=390784
The latest version is 2.82-0.06.
Happy ReadyNASing! :D
Sergey.
Sergey.
- cosmos1Aspirant
ssurba wrote:
you can also edit settings.json without SSH, this file can be found \Transmission network share. Don't forget to restart Transmission after editing.
Hehe, didn't think about that! :)
BTW, excellent build you gave us Sergey! I'm also using transmission-remote without any issue at all. Awesome :thumbsup: - ssurbaGuideHi ashani,
Sergey. - cosmos1AspirantI have not done it, but guess the way to do it would be the following. First, enable SSH root access (see caveats about warranty though) on your netgear. Disable transmission from the web interface. Then ssh to the netgear box and edit the settings:
vi /transmission/settings.json
... to enable authentication as per https://forum.transmissionbt.com/viewto ... 362#p35883
Save the file and then re-enable transmission from the web interface. - ashaniAspiranthello,
i am looking to enable web authentication on my transmission installation as i use port forwarding to access my web GUI remotely - cosmos1AspirantAwesome work, can't wait to try it at home mate!
- ssurbaGuideHi phpandsql, this problem should be fixed in latest version, please try it.
- phpandsqlAspirantnot sure why, but all the settings e.g. speed limit and download directory do disappear every now and then, and it always goes back to the default.
- cosmos1Aspirant
ssurba wrote: Hi Cosmos,
thank you for your detailed input.
"prefetch-enabled" and "utp-enabled" config parameters were set to default values and I did not change them.
I'll try to get more info about POSIX_FALLOCATE function and maybe try to disable it, if possible.
But from my point of view, if you are not copying/deleting/moving files on your NAS very often, fragmentation should not be an issue. I would not bother about it at all. :-)
Your request on including transmission-remote client is accepted, I will include it in next build.
Cheers, Sergey!
Sergey, you are awesome mate, thank you!
IIRC, when running configure, a file should be created that shows the values of the configure values, one per line like POSIX_FALLOCATE=1. Can you please paste here this file? I am very curious on the functions supported by the box. - ssurbaGuideHi Cosmos,
Cheers, Sergey! - cosmos1AspirantAnd another request: I am mostly accessing my netgear over the internet with SSH. Would you please consider adding transmision-remote and/or transmission-remote-cli to your package? I don't need fancy stuff, even transmission-remote would suffice :)
Once again THANK YOU for your awesome and FREE package. YOU ROCK!
