Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
JarnoG
Jan 13, 2012Guide
The Duo has enough resources to run Transmission, but you have to limit the settings a bit. To change these settings, you will have to disable Transmission, then open this file:
\\IpOfNAS\addons-config\Transmission\transmission-daemon\settings.json
Change the following settings:
"cache-size-mb" should be a few MB (~2 or so)
"peer-limit-global" should be around 50
"peer-limit-per-torrent" should be around 5
Then start Transmission again and it should work better.
