Equinox1
Apr 14, 2016Guide
Transmission crashing after a couple of seconds
I've had the canonical Transmission plug-in installed on OS6 for months (the 3.0.8 that you install from the UI). Yesterday I noticed that there is a newer version on super_poussin dropbox, so I tried to installed. I got the message that it installed fine, but then it disappeared from the installed app list.
After a few cycles of installing and uninstalling, I had a look to the log file, and I noticed that the transmission daemon is getting killed and revived every couple of seconds. When it goes does, this is the message in the log:
| Message | traps: transmission-da[24271] trap invalid opcode ip:42905c sp:7fc8c199ac20 error:0 in transmission-daemon[400000+6b000] |
Any ideas on what this could be, and how to reset the whole thing?
yep now install the transmission interface package :) (also in my dropbox)
- super_poussinVirtuoso
can you try the new 2.92 version in my dropbox ?
