Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
Sushiboy
Feb 09, 2012Aspirant
perfectdark wrote:
i set mine up as follows
"cache-size-mb" 2mb
"peer-limit-global" 50
"peer-limit-per-torrent" 5
and transmission responds faster now but the torrent downloads are slow
That's bad news for me, as those kind of peer limits are too constraining. It looks like I'm stuck with 2.22, which I've been using for a couple years, as it's the latest version I seem to be able to run on my Duo that's stable. Anything after that routinely disconnects on me.
The standard settings (and the ones I use) for 2.22 are:
"cache-size-mb" 2
"peer-limit-global" 240
"peer-limit-per-torrent" 60
For 2.42 it's:
"cache-size-mb" 200
but even setting the cache to 2 doesn't stop 2.42 from disconnecting on me.
I hope an update is in the works which fixes these stability problems.
