Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
Sushiboy
Feb 13, 2012Aspirant
JarnoG wrote: The Duo only has 256MB, so if it has much other stuff running, the memory will be full quickly. If you set the cache size to 8MB, Transmission will want to use 400MB of ram, which the Duo doesn't have, so the swap will be used. If 240 peers with 2MB each worked in 2.22 and it doesn't work in 2.42, then apparently, there's a problem with running Transmission while swapping a lot.
Thanks for this explanation. But I'm running 1GB of memory, and it still disconnects with 2.31 and 2.42.
I found some interesting comments at https://forum.transmissionbt.com/viewtopic.php?f=2&t=12746 regarding settings.json settings in 2.42. Might there be some applicability to the problems many of us have experienced with it?
• "max-peers-global": 200, invalid for 2.42--remove
• "open-file-limit": 10, invalid for 2.42--remove
• "peer-limit-global": 100,
"peer-limit-per-torrent": 20, Reduce both by 50%.
• "upload-limit": 100,
"upload-limit-enabled": 0, Both are invalid for 2.42--remove
• "utp-enabled": true, Try setting to false. Daemon must be quit before making changes.
