Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
JarnoG
Feb 14, 2012Guide
If I recall correctly, I read on the transmission forums somewhere that the "max-peers-global" and "open-file-limit" haven't been used since version 1.4 or so. As far as I know, they are ignored and will not cause problems. The "upload-limit-*" have been replaced by the "alt-speed-*" and "speed-limit-*" in version 1.5. (see the link given in the topic your link to)
It also says that "open-file-limit" is used in version 2.31 and older, so, if 2.31 crashes for you too, that might not be the problem. You can try to reduce the queuing and peer limits to see if this works.
