Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
Sushiboy
Feb 14, 2012Aspirant
Thanks JarnoG. I appreciate your patience with me. Your explanation makes a lot of sense.
I attempted once again to install 2.42 with the following settings:
"cache-size-mb": 2,
"peer-limit-global": 100,
"peer-limit-per-torrent": 10,
So far so good (keeping my fingers crossed).
As far as thinking I needed the higher peer limits, I can probably get by without it.
Thanks again for all your help. It's much appreciated.
"cache-size-mb": 2,
