Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
Sushiboy
Feb 14, 2012Aspirant
I was successful in adding back all my previous torrents. Smooth sailing. And then... After adding just one more newly created torrent, the dreaded
I then disable Transmission, changed to the following settings:
"peer-limit-global": 50,
"peer-limit-per-torrent": 5,
Still no go. I then deleted from the queue all my torrents and attempted to add just the one newly created torrent again. Within seconds the dreaded message appeared again! To say the least this is maddening. I have never ever experienced anything like this with 2.22.
Any final suggestions?
