Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
JarnoG
Feb 15, 2012Guide
To me it seems that you've got one torrent that gives the problem, while all the others work just fine. When you're in the webGUI of Transmission, go to the settings window and disable PEX, DHT and LPD on the Peers tab and UTP on the Network tab. Those are extra services that Transmission uses to improve downloading. It might be that the torrent uses one of these services which then causes Transmission to crash.
