Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
JarnoG
Feb 15, 2012Guide
I'm out of options, maybe someone else has a few more suggestions. It seems to me that there's a problem with only a few of the torrents you created while most is working just fine. If it is not to much of a problem, you could just stop seeding those few torrents.
