Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
frarev
Feb 29, 2012Aspirant
Hi everybody
Just read all the thread because I have the same problem with Transmission 2.42.
Everything began fine : installation was OK, using web interface was ok, and I downloaded few files.
But regularly, i have a "Connection failed" error message and the service stops (green light turns to gray).
My question is : does 2.22 supports magnet url to set the torrent file ?
