Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
JarnoG
Mar 01, 2012Guide
you can just edit the settings.json file via whatever protocol you like using a text editor that supports unix-files. I use Notepad++ and edit the file over CIFS.
If you don't see the addons-config share, you can create a share for it and set permissions for whatever user you like. This might give Transmission permission-problems though. You can also find the directory on the c. You will have to log in (using CIFS) as admin and go to \\ipofnas\c\addons-config\Transmission\transmission-daemon\ to find the settings.json file.
The first option lets you edit the file without having to log in as admin, but might give permission problems for Transmission. You don't have that problem with the last option, but you will have to log in as admin
