Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
mdgm-ntgr
Mar 01, 2012NETGEAR Employee Retired
The share is automatically created when you install the Transmission add-on for Sparc or x86.
Do you have the Duo v1 or the Duo v2?
