Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
JarnoG
Mar 02, 2012Guide
You can not change the password using the webinterface, you will have to edit the settings.json file.
Stop the Transmission add-on and open settings.json
Change "rpc-password" and "rpc-username" to whatever you want. The password should be between the "" and not start with {.
After saving the file, start the Transmission add-on again.
It will automatically change the plain-text password in the settings file to a encoded one and save that.
Make sure to set "rpc-authentication-required" to true or it will not use the username/password
