Dr_Strangelove
Jan 12, 2012Aspirant
Transmission add-on crashing on ReadyNas Duo
I'm having stability issues with Transmission on my Duo. The web GUI loses connection with the add-on and the green little indicator in the Duo's web GUI goes gray. I interpret this as the process cra...
PiddeP
Mar 04, 2012Aspirant
I'm having trouble getting Transmission 2.40 to work on an Ultra 2. Regardless of which setting file I use (I've tried the settings files that's been posted) I get "permission denied opening folder XXX" after a while and the transfer is aborted.
Do I need to makesome chmod-changes for it to work?
