veevella
Jan 24, 2013Aspirant
Transmission BT not downloading to specified location
Hi, I am having issue with the Transmission BT add-on for my ReadyNAS NV+ v2. I had no issue prior to moving house, but ever since, I cannot seem to locate files that are downloaded. I note that I...
veevella
Jan 26, 2013Aspirant
Hi Kullyrai,
Thanks for taking the time to reply.
I have been using Windows to search for the files. Don't know how to use ssh I'm afraid, so I haven't enabled it.
I've tried logging in as Admin, and as a user, and still I cannot find the files.
My setup is the same as that which I had previously - prior to moving house, and that is why I cannot understand why it now won't work.
I've just noticed that the listening port is closed, not sure if that causes any issue. The NAS does seem to be downloading - fan kicked into gear the other day when it was super hot. I just don't know where it is going.
Thanks.
Thanks.
