noilly
Nov 05, 2011Aspirant
Transmission constantly turns inactive
Hi, I am having an issue where the Tranismission service seems to constantly become inactive. I.e. The active "LED" is grey (not green.) I am running Transmission 2.42 and RAIDiator 4.1.8. I ...
parapligas
Nov 07, 2011Aspirant
same think with me !! i have the readynas duo 4.1.8 and the transmission keeps dieing.. when it starts downloading it's all good about 10 min then suddently the bandwith falls to 0 kb/s and after will i can't even contact with the page of trasmission thru safari !!
i did a small reaserch and i found some post's there where sayin'g that you have to change the permissions to the usage of cpu and stuff tha you have to be atlist a programer or nowing command line on unix.
If someone now's a more simple way to fix this problem will be very helpfull !!!
