noilly
Nov 05, 2011Aspirant
Transmission constantly turns inactive
Hi, I am having an issue where the Tranismission service seems to constantly become inactive. I.e. The active "LED" is grey (not green.) I am running Transmission 2.42 and RAIDiator 4.1.8. I ...
spiritx
Nov 21, 2011Aspirant
Hello,
To may be help Super Poussin to solve the problem i've logs :
Firstly i've this one
And after few minutes :
Kind regards
Nov 21 20:27:23 readynasduo transmission-daemon[20094]: TorrentName Piece 471, which was just downloaded, failed its checksum test (peer-mgr.c:1791)
Nov 21 20:40:45 readynasduo kernel: oom-killer: gfp_mask=0x200d2, order=0
Nov 21 20:40:45 readynasduo kernel: [8006698c : read_swap_cache_async+0xb8/0xd8 ] [8005e724 : do_swap_page+0x3d4/0x48c ] [8005f084 : __handle_mm_fault+0x154/0x4a4 ] [803410f4 : 0x803410f4 ] [80340110 : 0x80340110 ] [00001009 : 0x1009 ]
Nov 21 20:40:45 readynasduo kernel: Mem-info:
Nov 21 20:40:45 readynasduo kernel: DMA per-cpu:
Nov 21 20:40:45 readynasduo kernel: cpu 0 hot: high 0, batch 1 used:0
Nov 21 20:40:45 readynasduo kernel: cpu 0 cold: high 0, batch 1 used:0
Nov 21 20:40:45 readynasduo kernel: DMA32 per-cpu: empty
Nov 21 20:40:45 readynasduo kernel: Normal per-cpu:
Nov 21 20:40:45 readynasduo kernel: cpu 0 hot: high 18, batch 3 used:1
Nov 21 20:40:45 readynasduo kernel: cpu 0 cold: high 6, batch 1 used:5
Nov 21 20:40:45 readynasduo kernel: HighMem per-cpu: empty
Nov 21 20:40:45 readynasduo kernel: Free pages: 3920kB (0kB HighMem)
Nov 21 20:40:45 readynasduo kernel: Active:13593 inactive:317 dirty:0 writeback:0 unstable:0 free:245 slab:636 mapped:13353 pagetables:0
Nov 21 20:40:46 readynasduo kernel: DMA free:1168kB min:112kB low:128kB high:160kB active:0kB inactive:0kB present:16384kB pages_scanned:0 all_unreclaimable? yes
Nov 21 20:40:46 readynasduo kernel: lowmem_reserve[]: 0 0 60 60
Nov 21 20:40:46 readynasduo kernel: DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Nov 21 20:40:46 readynasduo kernel: Normal free:2752kB min:1840kB low:2288kB high:2752kB active:217488kB inactive:5072kB present:245760kB pages_scanned:13303 all_unreclaimable? no
Nov 21 20:40:46 readynasduo kernel: lowmem_reserve[]: 0 0 0 0
Nov 21 20:40:46 readynasduo kernel: HighMem free:0kB min:512kB low:512kB high:512kB active:0kB inactive:0kB present:0kB pages_scanned:0 all_unreclaimable? no
Nov 21 20:40:46 readynasduo kernel: DMA: 1*16kB 0*32kB 0*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 1168kB
Nov 21 20:40:46 readynasduo kernel: DMA32: empty
Nov 21 20:40:46 readynasduo kernel: Normal: 58*16kB 7*32kB 5*64kB 2*128kB 0*256kB 0*512kB 1*1024kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 2752kB
Nov 21 20:40:46 readynasduo kernel: HighMem: empty
Nov 21 20:40:46 readynasduo kernel: Swap cache: add 431022, delete 428371, find 59611/128573, race 2+0
Nov 21 20:40:46 readynasduo kernel: Free swap = 40272kB
Nov 21 20:40:46 readynasduo kernel: Total swap = 255968kB
Nov 21 20:40:46 readynasduo kernel: Free swap: 40272kB
Nov 21 20:40:46 readynasduo kernel: 14141 pages of RAM
Nov 21 20:40:46 readynasduo kernel: 245 free pages
Nov 21 20:40:46 readynasduo kernel: Out of Memory: Kill process 20094 (transmission-da) score 43412 and children.
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20094 (transmission-da).
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20095 (transmission-da).
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20096 (transmission-da).
Nov 21 20:40:46 readynasduo kernel: Out of memory: Killed process 20097 (transmission-da).
Kind regards
