noilly
Nov 05, 2011Aspirant
Transmission constantly turns inactive
Hi, I am having an issue where the Tranismission service seems to constantly become inactive. I.e. The active "LED" is grey (not green.) I am running Transmission 2.42 and RAIDiator 4.1.8. I ...
BikeHelmet
Dec 09, 2011Aspirant
noilly wrote: 3. Navigate to and open the settings.json file (..\addons-config\Transmission\transmission-daemon\). Notice that on the fresh install of v2.42, the settings.json file has a value cache-size-mb = 200
4. Change cache-size-mb tocache-size-mb = 2
Is the default value in 2.42 so high?
I found any value above ~20 caused stability issues in past versions. I think I had mine set to 8MB to cut out a bit of I/O without gobbling all the RAM.
