noilly
Nov 05, 2011Aspirant
Transmission constantly turns inactive
Hi, I am having an issue where the Tranismission service seems to constantly become inactive. I.e. The active "LED" is grey (not green.) I am running Transmission 2.42 and RAIDiator 4.1.8. I ...
Imem
Dec 15, 2011Aspirant
michelefaccini wrote: I had the same problem which I solved using Transmission Remote GUI ( see http://code.google.com/p/transmisson-remote-gui ).The interface is not complete as the uTorrent one but anyway it works...When I will have enough time, I will try installing uTorrent which is The One for peer to peer.....
Hi there any one get this to work?
Is there any permissions i need to solve?
in Connection...
Remote host : my nas name or ip
port: the port for Transmission or webgui port?
User name: admin
Password: password1 (its the default password for transmission)
I get timed out all the time...
