noilly
Nov 05, 2011Aspirant
Transmission constantly turns inactive
Hi, I am having an issue where the Tranismission service seems to constantly become inactive. I.e. The active "LED" is grey (not green.) I am running Transmission 2.42 and RAIDiator 4.1.8. I ...
Sushiboy
Feb 08, 2012Aspirant
Thank you noilly!
The "cache-size-mb =" at 2 seems to have cleared this problem for me. It had become such a nuisance that I downgraded Transmission to 2.22 a year ago. No problems with it to speak of, though the browser interface was, at times, a bit sluggish.
Before upgrading back to 2.42 I checked the cache-size in the settings.json file and, sure enough, it was set to 2. Apparently that was the default size for ver. 2.22, because I'd never changed anything in settings.json until today.
UPDATE: I spoke too soon. After re-adding some torrents it started disconnecting again. VERY frustrating. I really like the new features since 2.31, but they're of no value if it's constantly disconnecting. I'm back to 2.22.
Doesn't anyone have a way of fixing this problem?
BTW: I'm running 1GB of memory (and yes, my memory tests out just fine).
