Woodstock82's avatar
Woodstock82
Transmission: Error upon installation, cant delete now
Hi,
first time ReadyNAS user. (Duo, Raid 4.1.8.)
I just downloaded Transmission, but upon installing it said "error upon installing"
After that I still got some messages ("If you like this..." / "You need to set settings..." ), however....I cant launch, remove, or do anything with it now.
It is located in my Services > Installed Add ons screen, but when I try to do something with it, my browser freezes...
Any clue how I can undo this faulty installation alltogether?
Also......anybody a clue how I can determine if I have a Duo V1 or Duo V2....?
I figured, nothing bout V2 mentioned on the box, so it must be a V1, and thus Sparc, right?
ProSupport for Business
