KgOlve
May 08, 2012Aspirant
Transmission installation problem
Hi, I've got a Netgear Ultra 2 NAS, and am trying to install Transmission BitTorrent client. However earlier on when i tried it had a "Failed installation" for some reason. Nothing appeared in the...
WhoCares_
May 09, 2012Mentor
"Connection closed by remote host" generally means you're using either the wrong password, the wrong username or both.
For SSH access the username is "root" (not "admin") but you have to use the password for the admin user ;)
-Stefan
-Stefan
