KgOlve
May 08, 2012Aspirant
Transmission installation problem
Hi, I've got a Netgear Ultra 2 NAS, and am trying to install Transmission BitTorrent client. However earlier on when i tried it had a "Failed installation" for some reason. Nothing appeared in the...
Ben_skyrme
May 18, 2012Aspirant
WhoCares? wrote: The command used to ssh into the NAS from a terminal would be ssh root@ip.address.of.nas
-Stefan
Thanks Stefan,
any idea on this?
Bens-MacBook-Air:~ Ben$ ssh root@192.168.0.21
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that the RSA host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
4f:7f:75:da:7e:8d:6d:d9:f9:57:a8:b9:f9:b5:ca:94.
Please contact your system administrator.
Add correct host key in /Users/Ben/.ssh/known_hosts to get rid of this message.
Offending key in /Users/Ben/.ssh/known_hosts:2
RSA host key for 192.168.0.21 has changed and you have requested strict checking.
Host key verification failed.
I managed to get around it using Putty on windows and run the suggested commands, but i still can't get transmission to run, not even older versions? please can you take a look at this thread and see if you have any suggestions? http://www.readynas.com/forum/viewtopic.php?f=36&t=63327
Thanks again for the help mate
