KgOlve
May 08, 2012Aspirant
Transmission installation problem
Hi, I've got a Netgear Ultra 2 NAS, and am trying to install Transmission BitTorrent client. However earlier on when i tried it had a "Failed installation" for some reason. Nothing appeared in the...
WhoCares_
May 18, 2012Mentor
The output above means that either you have re-installed /factory-reset your ReadyNAS after having been able to SSH into it earlier or that your ReadyNAS uses an IP address that had been assigned to another piece of equipment before. Either way, the RSA host key that your Mac previously associated with the host 192.168.0.21 is different from what your ReadyNAS is presenting and that's what is causing the message. The reason PuTTY doesn't complain is that most likely it was the first time you used it to connect.
As for your installation problem: Sorry, I'm neither the author of Transmission on the x86 ReadyNAS platform nor do I have it installed/use it, so I can't really provide help there.
-Stefan
-Stefan
