3square's avatar
3square
Transmission Remote GUI path mapping help
Hello all
i'm using a RN102. I managed to get Transmission running, and got my way to edit the config file.
i can't seem to figure out how to do path mapping to open the torrent from the Transmission remote.
NAS-Libary\Transmission\Downloads
that is my path for my downloads. 'NAS-Libary' is one of the volume/drive in my RN102
here is what i have set for the local path mappings in the Transmission remote gui app.
Transmission/Downloads=\\NAS-Libary\Transmission\Downloads
I'm using OSX too btw.
any help would be appreciated.
  • thanks for the quick reply. still doesn't work.
    i've just try it as
    Transmission/Downloads=/NAS-Library/Transmission/Downloads
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Are you sure "NAS-Library" is the volume name?
    Sounds more like it could be the hostname for the NAS.
  • hi. yes it is the host name. i verify it from the frontview.
  • unfortunately no. i searched and found that post; tried everything on it.
    thanks for your help.
  • This is what I use successfully (on my PC) for my RN312 using Transmission Remote GUI
    /data/Videos/!downloaded=\\READYNAS\Videos\!downloaded
    ReadyNAS is the name of my NAS. Perhaps you are missing the double \\ ?
ProSupport for Business
