Chuck1806's avatar
Chuck1806
Network map
How do you remove an old satellite RBS50 that was damaged from the network map?
I open the satellite profile and can see the Details.
It indicates the Connection Type as "Offline" but no option to delete it.
  • Log into the RBRs web page using it's IP address using a web browser. On the Connected devices page there, if the RBS is OFF or not connected and had been there should be a Disconnect button for the RBS entry here that you can select to remove it from the system.
