MTeixeira
Jun 16, 2021Aspirant
Two failed disks at same time
Hi all, Last monday this NAS in a client reported at the exact same time the failure of two of the three drives - thus loosing the volume No prior warnings existed and this beeing a backup NAS the ...
- Jul 02, 2021
I Rebuilt the RAID5
Took the exepcted time. No errors whatsoever
Of course i dont trust this device anymore - it can be the disks but two failures at at the same instant with no smart errors and no errors on the test and on the rebuild points to some glitch on the NAS itself...
As it is 6+ years old I bought a new NAS for main backup and this will be secondary while it works
Thanks all
MTeixeira
Thank you for your reply
I am rather new to netgear, where can i find this smart_history.log via ssh ?
As to the configuration, is there a way to install new disks and create the volumes keeping the configuration or is the configuration in the disks themselves ?
Thanks
MTeixeira
OK, found it via donwload logs
No errors are reported.
Couldn't find any logs that report an error...
simply at 23h00 last monday: (23h00 is the time a backup starts to this device)
[21/06/08 07:59:00 GMT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[21/06/14 23:00:02 GMT] warning:volume:LOGMSG_HEALTH_VOLUME Volume 'RAID5' health changed from 'Redundant' to 'Degraded'.
[21/06/14 23:00:03 GMT] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel '2' (Internal) changed state from ONLINE to FAILED.
[21/06/14 23:00:04 GMT] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel '3' (Internal) changed state from ONLINE to FAILED.
[21/06/15 01:00:02 GMT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume 'RAID5' is 'Degraded'.
I made a disk test today via boot menu, is the result somewhere ? Can't find it.
I am concerned this may be some malfunction in the NAS itself. any pointers on how to diagnose this ?
Thanks
- SandsharkJun 17, 2021Sensei
You can create a complete log .zip from SSH with rnutil create_system_log -o <filename>.
- StephenBJul 02, 2021Guru - Experienced User
If the test passes, you should see a completion notice in the log. If it fails, you'll see a failure notice in the log.
You can also download the log zip file. Volume.log should have an entry for the test (scroll to the bottom). It will also show you SMART stats for each disk.
It sounds like you have access with ssh. You can also use smartctl to look more closely at each disk. The -x option might be helpful, as it will include specific failures. You can also use smartctl to test disks independently.
