inavs's avatar
inavs
Viewing JPEGS from Ready NAS Remote
Is there a way to log into my NAS and view my Jpegs inside each folder without having to hit view one a t a time. I turned off encryption thinking that might be my issue but they are not viewable as photos until I click each one and open them. My goal is to back up my lightroom cr2 files export them to my NAS which will also allow easy viewing on my iphone. I do have Photos II on here as well but I need to create slide shows and send invites which is cool but I will use that in a different way. I want to be able to view my jpegs and or share them easily when I am with friends from my device. I am looking for a change view option?
Thanks
  • Having a preview feature of thumbnails would be useful.
  • I noticed that there are two additional files that are added to the folder that I added to the NAS. One is marked thumbdb and the other one is labeled "out"? The thumbdb is not supported on the iphone and I wonder if this is intended for viewing all pictures at the same time.
    This application doesn't appear to receive much if any support or improvements from Netgear. I use Carbonite and their remote viewing interface is superior in regards to accessining ansd viewing photos. Jpegs are immediately opened up and viewable as soon as I click on the folder.
    So if I have an event that I shot with 100+ photos it's a drag to try to find a particular one in the group.
  • I left out one important detail and that is that this is a problem when viewing on apple hanheld devices iphone and ipad using the app for ready nas remote. Unlike a computer there is no option for different views that allow you to swap between thumbs, tiles etc... Does anyone know if there is an app that would give me that ability or is this a limitation of the Netgear remote app for iphone/
ProSupport for Business
