Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
JackStuder
Jun 24, 2009Aspirant
If it is a PC only application, you could always install windows inside a virtual machine using vmware fusion on your mac and do it from there.
otherwise, you can also look into buying a network media tank (aka popcorn hour - http://www.popcornhour.com/onlinestore/) and forget about the PS3
