Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
TeknoJnky
Jun 24, 2009Hero
the duo (and nv/nv+) does not have the cpu power to do any type of dynamic transcoding, it will only stream the files as they are, it can't change or re encode them.
I don't know if the ps3 supports mkv files or not. If it does, then maybe something in the ready dlna server can serve those files, but if the ps3 does not then nothing that runs on the duo will be able to convert them to files the ps3 can play.
hope that helps explain
