Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
huongalt
Oct 07, 2009Aspirant
you could set up media tomb (some very basic scripts need to be written) on your pc and transcode on the fly to the PS3 using the NAS as a file source. alternatively you could use (from a bad memory) as program called ps3 that will do this on the fly and comes in both linux or windows flavor, or transcode the files before you store them on the NAS, there are a lot of tools out there for exactly this sort of work flow.
